I know I’ve posted a lot recently, but hope someone will be able to help on this as well.
I assume the answer is pretty simple, but I just can’t find the information I am looking for
There are a some actions that start by defining a tags, and applying that tag to a new draft in the end.
My question is how do you do this for multiple tags?
For example I have an action that starts with something like this const logTag = "list";
And later it will d.addTag(logTag);
How do you add multiple tags for “list”, “act-on”, “work” for example?
For now, my work around is to just add them in sequence
Which is fine for now, but this means I need to tweak multiple areas of the script(at least the end), and it can mess up queries in the middle of the script.
I was hoping for a solution like const logTag = "list", "act-on", "work";
(this did not work)
Where you only need to change 1 of the lines.
There is probably a very simple solution, and this may be a very stupid question, but any help would be appreciated.
To clarify though, this example would mean I need to change the scrip for to add the code to the draft right?
Looking at agiletortoise’s “Add to list” action as an example (it is actually originally the one I wanted to be able to add multiple tags with)
Towards the start
const listTag = “lists”;
Then after multiple things happen,
d.addTag(listTag);
Towards the end.
Is there a way to just change the former, keeping the latter intact, and still add multiple tags?
Or maybe that just isn’t how the latter script works?
