Hi,
I’d like to add the modified date to the body of a Draft.
This is so I can then share the batch of Draft to Apple Notes and at least
have a record of the date the note/draft was last modified/created.
Ideally I’d like to do this on a selected list of Drafts, if not individually will do.
A simple script snippet to add the modified date to the end of the text of a draft would look like:
// get the modified date
let dateStr = draft.processTemplate("[[modified]]");
draft.append(dateStr);
draft.update();
If you setup an action with that script in a script step, it could be run on the current draft, or used with selected drafts in the draft list using “Run Action” via operations on iOS, or the context menu on Mac.
