I tried the Markdown syntax, e.g. \alpha, but could not get the Greek letter alpha in the preview.
Could I input greek letters in Drafts at all?
That is LaTeX syntax, not Markdown. Some particular setups may support this, but it is supporting embedding of LaTeX syntax.
MathJax is a common way of approaching the inclusion and translation of LaTeX mathematical syntax, and there is an action in the directory for this.
If you only want Greek letters, a couple of simple alternatives could be:
α)Hope that helps.
Helps a lot!
Many thanks!
