kangnux
1
I want to transfer parameters between steps like this.
Step1: I get the keyword.
let [st, len] = editor.getSelectedLineRange();
keyword = editor.getTextInRange(st, len);
Step2: I want search it in google by URL.
https://www.google.co.jp/search?q=keyword
but I don’t know how to realize this…
Javascript variables will carry over from one Script step to another.
If the step you want to use it in isn’t a Script step, then you should store the value in a template tag, which you can then use in your later step.
So, something like this:
draft.setTemplateTag(‘keyword’, editor.getSelectedText())
and then in your URL, use [[keyword]] to pull in that value:
https://www.google.co.jp/search?q=[[keyword]]
kangnux
3
Thank you very much .
It really worked.
