I have what might be a really dumb question that I feel like should be easier than I’m making it.
My goal is to choose from a menu. Then for the next step to be to add a txt to Dropbox, with the contents being the draft, and the title of the file being MenuChoice.txt
I tried a script step to generate the menu and then the built in add to drafts and using [[MenuChoice]].txt as the file name but it doesn’t actually fill in the choice, but rather the literal characters. [[MenuChoice]].
Am I missing something obvious. The script I have is this.
var p = Prompt.create();
p.addButton("Option");
p.addButton("Another");
p.addButton("TheThird");
var didSelect = p.show();
var MenuChoice = p.buttonPressed;
