I use this action frequently. However, it converts “—” into “—“.
I’ve tried multiple variations in debugging. Sometimes it only happens if boxes are actually moved. (If there are checked boxes). Sometimes it’s not on the first run of the action, but every run thereafter (sometimes then only if there are checked boxes, other times it just happens - but only the second time and every time thereafter but not the first).
I don’t want to change system level smart punctuation setting. Is there a way to create an action that does the same thing but without messing up the 3-hyphen section breaks?
