I recently published two actions that are handy to open flagged or tagged (either scoped or nested tags) drafts especially from widgets.
I get an empty dialog box that says ‘select tag scope’ for the second one, there is nothing to select just a cancel button.
Do you have any tags that use scopes or are nested?
you make a fine point there ![]()
@zinoff I could create an action that lets you select from all available tags though ![]()
I guess I have a panel for that ![]()
Here you go: open tagged draft | Drafts Directory
