I have two Exchange calendars, which iOS (?) causes GetAllCalendars to see them as both being named “Calendar”. Is there a way to handle this in a Draft script so I can tell it which “Calendar” I want to use?
I am trying to create an action that will create a draft for meeting notes for my next meeting. Similar to the Prepare MoM action.
Calendar names are applied on the system side, not the client side, so I don’t think there is currently a way to distinguish directly. If Greg added a check for the calendar colour attribute from the Calendars app (if that’s even possible for a third party app), then that would give you some control over what you could use to identify the calendar.
As far as I know, all you can do at this point is use the calendars content to identify it. If you put a future event in a calendar (far into the future), and check for its existence when iterating through the two calendars, that should allow you to distinguish between the two.
