Hello can you tell me a script that would by analogy with the GPT script, Make a request to Gemini?
In ideal with to pick [[selection]] (if there is no one, then pick full draft text
Drafts does not currently have any purpose-built integration with Gemini. I’m sure it could be used directly with HTTP scripting, but I haven’t seen any examples of that so far.
I expect to be adding Gemini integration in a release soon, so if you are not an experienced scripter, it might make sense to wait a little while until official support it rolled out.
I found plugin For Obsidian For gemini, maybe someone can use some of these For a Drafts?
Will the next release also include Claude integration?
