I must say this has been the most responsive community I’ve ever seen. Thank you for all those who have helped me tremendously in providing these actions, I have nothing but gratitude towards everyone and again, let me buy you a few cups of coffee or beers to show my appreciation.
As you can see, its a single column CSV with multiple lines. Once I get this exported CSV, I just found out that Drafts can import them and so I imported them into a Workspace and they now look like this in Drafts
Now the action will produce a CSV titled CDExports for the sake of naming the file.
which will remove from column A the text string that looks like this which is at the end always {{c1:: whatever text string/s are here }} and create column B with that same text string but without the
{{c1:: }}, meaning it wil remove this encoding the text string has and just paste in column B as pure text and the output CSV will like this:
The goal is for Drafts to create a CSV via an action that moves the portion of the text strings that has the curly brackets eg. {{c1:: answer }} into column B, so basically create a new column, column B, and paste the content of the curly brackets code without the curly brackets just the actual answer.
Thanks @crownandbridge. The scripting shouldn’t be too complicated but as @sylumer suggests, there’s another thread going and this is definitely something that’s solved using regular expressions. Were you able to take a look at the thread and recommendations made there?
