AFAIK “focus mode“ -Mac- is enabled according to system settings… any more detailed explanation…?
please
please
I’m not sure what this question is about or how it relates to Drafts. Could you provide more explanation?
Simply stated… is there a Focus mode in Mac Drafts?
Focus modes are an OS feature so no. But Drafts does support focus filters. Here’s the excerpt from the Drafts 33 release notes.
Focus Filter
Drafts offers a Focus Filter which allows you to configure aspects of the app when your Focus mode changes at the system-level. Focus Filters are configured in the OS Settings app. If you add the Drafts’ Focus Filter to your Focus mode configuration, you can use it to apply a workspace, change themes, change loaded action groups, and other options. The Focus Filter is currently available only for iOS, but will be available on iPadOS 16 and macOS 13 (Ventura) later this Fall.
Thanks Stephen, but as you said, it refers to Drafts 33…
Yes. This was added years ago. you can still see it in the Settings as it says.
sorry, not clear… ok for iOS, but was FF added to macOS?
Yes. If you have a look in exactly the same location within Settings it’s there. Are you having some sort of trouble finding it?
found it! not so obvious actually…
