is that possible?
Sometimes I lost my drafts (I don’t see them…) do to some filter I don’t see…
is it possible to have a flat chronological view of all my drafts?
is that possible?
I’m not sure exactly what “flat chronological view” means - but it sounds like what the draft list is, no? The “*” all tab shows both the inbox and archive, if that’s what you are looking for.
Thanks, my fault!
BTW, is there a way to dedupe duplicated drafts?
Assuming you are deduplicating by content you could write an action to do that. It gets more complicated if you want to do things like also check tags, creation location, etc. You would also need to decide things like do you want to check against trashed drafts. You just need to have a clear idea of what you actually want to test against. After that it is just a case of either brute force checking everything of using Drafts’ querying to check - I strongly suspect the latter would be much faster… but if you have a lot of Drafts this is still going to run for a a while.
You would also need to decide which of any duplicates gets to stay (how do you decide?) and then action it. Possibly with a confirmation and summary.
A simple choice is to keep tagged items and to throw away same content dupes no tagged…
