Hey, I’m trying to cleanup some metadata before I import a Draft into Obsidian. Obsidian can’t have “: / |” in the backlinks but often a podcast or episode title contains them. I’ve used the regex to ignore “podcast:” and “episode:” so those ":"s aren’t replaced.
I know the lines will always be [6] and [9] and so I want to replace all instances of these symbols with " -" before I import them. Would be great if I could run this on multiple Drafts at once.
Here’s the code I have so far:
// clean up Drafts metadata
// define regex to use...
const regexOne = /(?<!podcast):/gm;
const regexTwo = /(?<!episode):/gm;
// define replacement expression...
const replaceWith = " -";
let podcastName = draft.lines[6];
let episodeName = draft.lines[9];
// do the replacement...
draft.content = draft.lines[6].replace(regexOne, replaceWith);
episodeName = draft.lines[9].replace(regexTwo, replaceWith);
draft.update();
As you probably guessed, this replaces the whole Draft with line [6] and I’m not sure how to target just line [6] or [9].
Here is an example of the metadata. I haven’t tried replacing “/” or “|” yet. Just working on the “:” for now.
# How To Start Your First Business in 48 Hours - Noah Kagan - 00:16:11
class: podcast clip
type: podcast clip
date added: 2024-02-03
time added: 07:26:51
podcast: [[Deep Dive: with Ali Abdaal]]
creator-host:
guests:
episode: [[How To Start Your First Business in 48 Hours: Noah Kagan]]
Any pointers on how to target those lines when updating draft.content would be greatly appreciated. Cheers!
If you would allow me to redefine your problem a little more simply, it sounds like you want to replace any instances of “:” that appear inside a [[wiki-link]] style link, right? Really doesn’t matter where they occur. That could be done with:
// regex to find all `[[link]]` style links
let re = /(\[\[[^\]]+\]\])/gm
// loop over results, replacing occurrences of “:” with “ -“
draft.content = draft.content.replace(re, function(match, text) {
return text.replaceAll(":", " -")
draft.update()
Well, if it works, no need to change, but you could simplify by doing all that in one replace. The way I wrote that replace, it’s using a function to do the replacements, which returns the result you want inserted. That function can do more than one thing, so this would work fine:
.replaceAll("/", "-")
// etc, etc.
draft.update()
