File write type Create does not add number suffix
Drafts 50.0.3, macOS Tahoe 26.2
I have a simple File action that saves drafts with their create dates as their file names in a folder on my Mac. The write type is Create.
If have used this action hundreds of times without any problem until this morning. One draft did not get saved and Drafts displayed a red warning. It took me a while to understand what happened but finally I did: I had duplicated the draft, which means both drafts had the same create date—and therefore the same file name.
According to the User Guide the write type Create should have added a number suffix to the second of the two files I had applied the action to. But it did not. Seems to be a bug, or am I wrong?
