Exporting to Obsidian
Is anyone using Obsidian? Just started to give it a whirl however struggling to find the best action to export from Drafts into it. Anyone got any tips?
Many thanks
I would suggest taking a look at the Markdown importer plugin for Obsidian.
I sync my Obsidian vault with Dropbox, so I can easily send a draft to the Dropbox folder. May or may not be helpful to you.
Hello.
I export as markdown file in the Drafts Export folder on iCloud with a tag toObsidian and Hazel on the Mac move the file into my Inbox in Obsidian and remove the tag in the process.
Eymeric
