Is it possible to export a draft with it’s tags becoming macOS tags?
I have the same question as dmccurley, does anyone have a solution?
It is not possible with Drafts built-in scripting functions at this time. It is “on the list” to add that functionality.
This is also something I’m interested in. Following.
I have the exact question and saw that OP posted this back in 2019. Is this functionality available already?
Yes, this was added a while back. If you are using the File action step to export, it has a tags field to assign tags. Using [[tags]]
in that field will assign the tags assigned in Drafts.
If you are scripting export, the FileManager script object has an setTags
function to attach tags to the output file.
