Sometimes I want to run one-off JavaScript code. The only way I know how to do that today is to create an action, add a Script step to it, edit that step, then run the action. Is there a more interactive way that I haven’t managed to find? The equivalent to a web browser’s JS console would be perfect.
Action Group
Actions
- TAD-Make Draft Executable
- TAD-Load Executable Draft
- TAD-Execute Draft
- TAD-Execute Test Function
- TAD-Execute Current Draft
- TAD-Execute Current Selection
- TAD-Execute Current Lines
Scripting actions documentation
Using the above, you just put your code in a draft and the actions reads in the content and you can run it.
I also have some extra stuff on logging if that is useful.
Oh, sweet! That’s much more convenient, thanks.
I still pine for a nice REPL, though.
