editor.showFind initial search string param
Hello!
This is a very non-urgent request/question. Previously, the showFind method of the editor object had 2 optional parameters:
  1. initial search text (string);
  2. preferAdvancedFind (bool)
I noticed a while back the signature changed to only include the preferAdvancedFind boolean. Would it be very annoying to add back the optional search string, perhaps as second param?
(As i was writing this, it occured to me that the change might have something to do with the addition of ‘search history’ submenu in the advanced Find/Replace window, which is faaar more useful and, if so, is probably a huge pain to redo, in which case nvm!)
I’m currently on the latest ios beta — 49.1 (702) — if that is relevant.
thanks!!
Looks like the docs did not get updated correctly. The initialQuery parameter is supported, it should be the second parameter, like editor.showFind(true, "query")
Many thanks and happy new year!
