when did editor settings got moved from the Status Bar to the menu on the mac?
Kind of annoying, I just lost 5 whole minutes tracking it down. Maybe I am alone in doing this, but I often need fiddle with the margin spacing depending on what I am writing.
Noted. This is the first I’ve heard of anyone noticing the change. It seemed redundant down there, since the menu has always been the primary means of access to settings panels on Mac. You can also easily pop it open with the ⌥⌘-, keyboard shortcut.
