Thought others might like this simple daily note shortcut I keep on my home page. It searches for a note titled with today’s date and creates it if it doesn’t exist
Available as download?
You can reduce that shortcut to a single action and simplify the URL to remove the callback that does not get used.
https://www.icloud.com/shortcuts/7a05843a081846bc916c3225aa62fa4e
However, when it runs the first time it prompts for creation.
To avoid that you could schedule an automation every day to create a draft - but you may end up with a redundant draft if you don’t add anything that day.
You could also then have something scheduled to tidy up such drafts, but overall you can have a shortcut with just a few steps that does the checking, creation, and openjng, without the extra prompt.
https://www.icloud.com/shortcuts/727b1fb1d7c0422ab897a5c21cafffd9
Note that you may want to tweak to include octothorpes for headings if you are using Markdown and want to set your title as say a level 1 heading.
Thanks for the clarification and the Shortcuts. It’s handy for quick access to today’s plan or journaling through the day
