I’m a longtime Drafts user and have been using the Dropbox connection to append to a Dropbox file from my iOS devices. In the past day or so, the Dropbox-related actions are failing and the log simply says “Dropbox Error:” with no actual error there (see screenshot from macOS Drafts, which is having the same issue):
I tried “Forgetting” the Dropbox connection and then reauthorizing it, which happens successfully, but as soon as I try to use an Action that uses that connection, it fails. Anyone else having this issue or have any idea what might be happening?
P.S. I sent a message about this to support@agiletortoise.com as well, but thought I’d post here in case others are experiencing this.
Edit: I’m having this issue with macOS 10.15.5 + Drafts Pro 21.1 and iOS 13.5.1 + Drafts Pro 21.1.
Dropbox made an unannounced change to how they deliver some API results last week. I’ve fixed the issue and submitted an updated build to Apple. Should be out in the next day or two when it gets through App Review.
They confirmed above that the issue was resolved by the update to Dropbox having changed their API. Given how old this post is, “still not working” is not an accurate description. The issue was resolved. Any issue you are experiencing is going to be a new issue. It may yet have a similar root cause, but unless you are on a very old version of Drafts, this is almost certainly going to be a different issue.
