Ok, this is a little silly, but I made a quick, simple action that summarizes your activity in Drafts in 2025. Not exactly Spotify Wrapped, but some might find it interesting. Just install and run the action from the directory to get a summary of drafts created, character counts, tags used…
I like it.
In the year 2025 you…
- Created 930 drafts
- Containing 1376204 characters
With the following tags:
- json a4d: 308
- menu a4d: 55
- history a4d: 42
- month a4d: 16
- log a4d: 15
- day a4d: 3
- journal a4d: 2
- archive a4d: 1
Probably, I’m not using Drafts frequently enough.
Created 79 drafts
Containing 37785 characters
watch: 4
dog: 3
food: 2
order: 2
Don’t forget if, like me, you use Drafts mostly as a starting or transient point in a workflow, and delete “used” drafts as you go, the volumes will appear lower because that data has been purged.
Created 2008 drafts
Containing 358001 characters
Would have guessed ~6/day, so there we go
Thanks Greg! Hny
Little late to the party, but…
Created 2498 drafts
Containing 2106723 characters
