Every time I try to run this I get a Red box with an exclamation point that says, “Save to Google Drive” and nothing happens.I have tried it on my Mac and iPad. It used to work fine, not sure what has happened.
I think I may have solved my own problem. Looks like my organization is blocking it. I will try from home and see.
Whenever an action fails, it’s best to start by looking the action log for error messages. Not always helpful, but often there will be troubleshooting ideas there.
That said, most likely something expired your Google credentials…like changing your Google password, or similar. Try to forget those Credentials in Drafts Settings (details) then try the action again to re-authenticate.
