Is there a way to assign a tile to the “last draft” action similar to what appears when you use the context menu (long press) on the actual Drafts icon? When editing the Drafts tile widget, I didn’t see that action as a choice. Screenshot below:
There is not. It would be a good addition, will put it on the list.
I made my own - using Launcher. “Return to last draft” is one of them…
See here but I’ve since updated to add that very function as another spot.
