Drafts IOS
Hello Greg,
by extended keyboard, it am referring to the action keys at the bottom of the draft in edit mode.
I suggest you add an option to sort (left to right, ie visible screen vs hidden keys) the extended keyboard based on frequency of key use.
When I tediously try to configure my keyboard from left to right, ie give priority to immediately visible keys vs those keys which require scrolling, I am basically trying to guess the statistical frequency of use of each key, something which would be much more accurately determined mathematically and which in addition would be flexible ie adapt to the addition and frequency of use of new keys.
You could call it some rather basic form of AI (I used to work with neural networks).
thank you
