To preface, I’m running the Sonoma beta. After Drafts was updated a couple of days ago (I’m excited to try the new Nested Tags), it’s not opening on my Mac, crashing within the first several seconds.
Have taken the following troubleshooting steps:
Restarted computer
Deleted and redownloaded Drafts
Deleted Drafts with AppCleaner (grabs app files not always deleted otherwise) and redownloaded
I don’t have any crash logs from you that are obviously from you in any of those places - but macOS 14 (23A5301g) is not the release candidate build of Sonoma. You have to update to the release candidate. You are on public beta 2 which is from July and very old at this point.
You can find a history of build numbers on WIkipedia. You should be on 23A339 or greater.
