When I sign into the Drafts Capture request for iCloud authentication, it just get recycled back to the request for authentication. It doesn’t actually capture this.
I had this problem before. Is there a way to make the captures more reliable? Seems like others use a Web Extension and that works.
First thing to try is other browsers on the same machine. Any issues? Could be a number of things from browser extensions, to network security policies.
I have tested, and have many people using Web Capture, in Chrome. So hard to troubleshoot these things when they seems specific to certain configurations/networks.
If you open up Chrome’s web inspector (View > Developer > Developer Tools), do you see any JavaScript errors in the console when trying?
Do you have any extensions active in Chrome, and if you disable them does it help.
Is this a corporate device and/or a corporate network that might be enforcing security policies related to iCloud?
