Hi!
I know a recent Drafts update provided for taskpaper use. I’m just starting out with taskpaper and looked through the Drafts guide but couldn’t seem to find anything on it … Thanks!
Hi!
Taskpaper syntax support has been in since version 5 was released a few years ago. Just switch the syntax of a draft.
I would think that as well as Highlighting support we should point the OP at automations to transfer Taskpaper format tasks to e.g OmniFocus.
That’s just an action directory search for “Taskpaper” isn’t it?
Yep. Which is precisely what the OP is going to need next.
