Hi,
I created some actions for Drafts to use for building a yacht sailing logbook and wondered if others might be interested in them or had similar ideas.
The approach is simple - one line of text per action entry. A standard layout/tagging to support easy export etc. Automatically capture data where possible or a dialogue box for input.
I currently have the following actions -
- create a new logbook - automatically titled with date and time stamp
- capture check-on/check-off info - engine hours, fuel and water levels, battery level, fender count, cleanliness and damage report
- capture a position log - automatically accesses longitude/latitude
- capture course and speed plus position
- capture a bearing
- export waypoints as gpx file to import into charting apps
I’m looking into getting tides and weather forecast as well - everything you’d need to make a passage plan - but sourcing Met Office forecast info in the UK isn’t straightforward - API keys etc
Example output below:-
Sailing Logbook - 20 May 2023 at 09:38
Check on/off date: 27/05/2023, 12:49:36
- Fuel Level: 100
- Water Level: 90
- Battery Level: 14.5
- Engine Hours: 101
- Fender Count: 7
- Clean Inside: yes
- Clean Outside: yes
- Damage Notes: None
W 27/05/2023, 12:50:39 51 30 8 N 0 4 53 W Cast Off ![]()
T 27/05/2023, 12:51:00 51 30 11 N 0 4 57 W
T 27/05/2023, 12:51:02 51 30 11 N 0 4 57 W
T 27/05/2023, 12:51:04 51 30 11 N 0 4 57 W
T 27/05/2023, 12:48:15 **51 29 19 N 0 3 6 W Mark: tester Bearing: 34° Notes: **
T 27/05/2023, 12:48:45 **51 29 37 N 0 3 44 W Heading: 90° Speed: 5kts **
W 27/05/2023, 12:50:41 51 30 11 N 0 4 57 W Moored ![]()
If there is enough interest I’ll look at versioning and posting.
Cheers,
Paul
