Drafts 5.5.1 is now available in the App Store.
- New: Arrange mode now has additional swipe actions to move a line to the top or bottom.
- New: When searching action list, include separators displaying action group name in results.
- New: Import file function (Tap and hold +, “Import File”) now recognizes drafts export, backups and action files and offers to individually import contents.
- Fix: Adjustments to swipe gestures to avoid accidentally triggering the action list when scrolling.
- Fix: Properly theme clear button and placeholder text in search fields and a number of fields in settings and action configurations.
- Change: Updates document icons for associated file types.
- Change: Adjust launch image slightly.
- Change: Tapping on tag in recent tag suggestions should not reorder the list.
Fix: Using
[[line|n..]]range could omit last line. This was a regression in the previous release. - Fix: Auto-list completion now participates correctly in the undo history.
- Fix: List auto-completion now enabled for MultiMarkdown syntax.
