Drafts 5.10 (macOS) is now available in the Mac App Store, details below.
- New: “New in Workspace” option in File menu to create new draft with workspace tags already assigned.
- Change: Better HTML output for fenced code block when using GitHub Markdown option.
- Change: Edit > Find > Search Drafts (shift-command-F) should work in Capture window.
- Fix: Better handling of activation of the app when no windows are visible.
- Change: Support broader data types in share extension.
