Drafts 48.1 has been released:
48.1
Known Issue
There is a hang issue using menus on iPadOS 26.0 with an external keyboard connected, and the action bar visible. This is a system-level issue. We are still trying to find a permanent workaround, but also it seems Apple has fixed this issue in the iPadOS 26.1 beta. For more details on this issue and workarounds, see this post
- All Platforms
- New: Enhancements to integration of Drafts data with on-device Foundation Models, including:
- New:
SystemLanguageModelobject has newenableAllTools()function that adds all Drafts’ Tools to the session. - New: More tools for Drafts integration with Foundation Models. These include support for:
- Finding drafts by tag, content
- Finding a draft by UUID
- Creating a new draft with text
- Opening a draft in the editor
- Moving drafts to inbox, archive, trash
- Appending/Prepending to the content of a draft
- Run actions on a draft
- Read more in the AI documentation
- New:
- iOS
- Fix: Workaround for problems navigating to the bottom of long drafts.
- Change: Use prominent styling to indicate link mode enabled status on iOS 26.
- Mac
- New: “Capture” command in menu bar now supports holding down the option key when selecting to get a new modal capture window.
- Change: Better tiling of multiple modal capture windows.
- Fix: Issue with capture window not maintaining proper sizing when draft list is visible.
- Fix: Workaround AppleEvent bug (behavior change?) on macOS 26 that prevents calls to “make draft” from continuing execution.
- Misc
- Fix: Workaround animation crash when running on visionOS.
