Drafts 47 has been released:
47.1
- Fix(iOS):
wantsFocusin prompts did not work reliably when the action was called from the Action Bar and multiple text fields were present in the prompt. - Change(Mac): Revealing search field in draft/action list should focus the field.
- Change: Refactor and improve sync logging, attempting to capture additional data at startup.
- Change: Better surface sync failure issues in the Settings interface.
- Change(Mac): Enable calendar day drop down on prompt date fields.
- Fix(iOS): Tweak prompt height calculations.
- Fix(Mac): Crash accessing contextual menu in action list.
- Refactor changelog to a package.
