Drafts 44.2 has been released:
44.2
Updates and Changes
- Change: Apple doesn’t publish its secret Apple Notes deep link URLs, and they are weird URLs based on an
applenotes:note/URL structure, but if you figure out how to get one, and put it in a draft, it will work with link mode and live links in the default Markdown syntax definitions now. - Fix: Auto-complete suggestions for linked draft titles which contain a forward slash should escape said forward slash in titles when inserting a link.
- Change: If the “highlight insertion point” editor setting is enabled, only highlight insertion point if no text selection is present.
- Change: Significant refactoring in editor code. In theory, should not effect any functionality – just laying some groundwork for future changes.
- Fix (iOS): Prompt buttons should better respect dynamic type sizes.
- New: Add new Claude 3.5 Sonnet Model to Anthropic known model list.
- Fix: A few fixes for the HTML to Markdown conversion functions used when pasting HTML, specifically for cases where the HTML contained multiple links that also had emphasis tags applied.
- Fix (iOS):
app.currentWindow.isDraftListVisiblereturned erroneous results on iOS. - Fix: Prevent link syntax patterns from wrapping a line in Markdown syntax definitions.
