After release an issue was found with the main window not appearing on versions of macOS prior to 14. A quick fix (v44.1.1) has been submitted to Apple and should be out very shortly.
Drafts 44.1 has been released:
44.1
Mac Find Default Change
Starting with this update, the Mac version of Drafts now defaults to using the macOS system find bar for find-replace by default. This is a simpler and familiar interface that should be a better experience for most users. The advanced find interface is still available and can be made the default by toggling the Edit > Find > Use Advanced Find option in the main menu if you have advanced find needs using regular expressions, etc.
Updates and Changes
- All Platforms
- New: Advanced Find now keep a history of recent queries that can be restored
- New: Advanced Find now offers button to reverse the values in the find and replace fields.
- New: Mail Drop setting to control whether attachment summary is included in the import.
- Change:
editor.showFind(preferAdvancedFind, initialQuery)adds newinitialQueryoptional parameter to pass in the initial find text. - Fix: Autocomplete for cross-links could erroneously suggests a recent draft with an empty first line, which would result in an invalid link.
- Fix: Command Palette cached recent actions too agressively.
- iOS
- Fix: Editor not updating immediately when editor settings changed.
- Change: Do not resign responder when backgrounded.
- Change: Update minimum required iOS version to 15.6 (from 15.0)
- Fix: Regression effecting links coloring and link mode activation.
- Mac
- Change: The editor now defaults to using the default system find/replace interface, which is simpler and more appropriate for most users. If you prefer the advanced find panel with reg. ex support, etc., enable “Use Advanced Find” in the Edit > Find menu, or in Settings.
- New: Add “Get Info” menu command to the File menu.
- Change: Some additional basic state restoration on Mac, like remembering collapsed toolbar.
