Drafts 28.1 has been released:
What’s New
See the Drafts 28 Release Notes for new stuff - this is a bug fix release.
Changes
Bug fix release addressing a few issues in release 28:
- General
- Change: Improve efficiency of workspace count calculations for widgets to avoid an issue that could result in a blank widget in some configurations.
- Change: Internal link previews now only work on iOS 15 to workaround issue that conflicted with use of cut/copy/paste menu.
- New: “Process Template” shortcut action which takes a template and draft and runs the text through the Drafts template engine to expand tags (like [[body]], [[title]], etc.)
- Fix: Prevent case where sending file to share extension would not capture content, or duplicate content.
- Change to find/replace regular expression configuration to support replacement of positive lookahead constructs.
- Fix: Case where an internal link by title could find drafts that had the query title string in some place other than the first line.
[[hashtags]]template tag should replace spaces in tags with “-”.availabilityproperty ofEventobject should be a read/write property, not read only.- Address several VoiceOver issues.
- iOS-Watch Only
- Fix: Add keyboard shortcuts (⌘-, option-⌘-,) back for Settings/Preferences and Editor Settings/Preferences.
- Fix-Watch: Background scheduling crash
- Mac Only
- Fix: Issue re-showing action bar if it was hidden.
- Fix: Issue configuring widgets on macOS 11 (Big Sur).
- Fix: Last line in action script editor clipping.
