Drafts 20.1 has been released. Primarily a bug fix release.
Details Below…
Drafts 20.1 (iOS) has been released in the App Store, details below.
20.1
New:
Draft.queryByTitle(title) returns array of drafts matching the title. This exposes the logic used by internal links to find drafts with a specific title. Docs
New: Link definitions now support
[[url:http://full.url.com/]] option to enable a full URL link external to drafts.
Change: Fine-tune the link matching regex a bit to avoid some nesting oddities.
Fix: Starting a line with a smart quote could temporarily align it to the right.
Fix: Editing an action from the results of a search in the action list should refresh the search to get the new version of the action.
Change: Locating draft by title should not be case-sensitive.
Fix: Crasher using down arrow on external keyboard past the last result in quick search.
Fix: TextExpander could not be enabled on iOS 12.
Change: Make “text” sort of draft list case-insensitive.
Drafts 20.1 (macOS) has been released in the Mac App Store, details below.
New:
Change: Fine-tune the cross-link matching regex a bit to avoid some nesting oddities.
Fix: Address scroll bar clipping content in prompts.
Change: Misc. minor visual tweaks.
Fix: If Action Log window had been closed and reopened, it might not update detail properly when selecting log entries.
