Drafts 15.2 (iOS) has been released in the App Store, details below.
- New: Create and Update Draft shortcuts can now set syntax definition for the draft. Also, shortcut actions which return drafts will contain syntax information.
- Fix: Some tweaks to gestures which open the side panels to avoid conflicts with some of the new iOS 13 text selection gestures.
- Fix: Case where using a Drafts URL could disable the new draft timeout the next time you return to Drafts.
- Fix: Some tweaks to background refresh on watchOS.
- Fix: Better syntax highlighting for [id][] style reference links in Markdown syntaxes.
New: MultiMarkdown syntax now supports embedded LaTeX markup with
\\[ \\],\\( \\)or$$style delimiters.
