Drafts 15.1 (iOS) is now available in the App Store, details below.
NOTE: In case you missed it, catch up on the big changes for iOS 13 in the release 15.0 notes.
Change: Apple Watch now requires watchOS 5.0 or greater.
New:
File Draft shortcut action which can update folder, tags and flagged status of draft without affecting content. Details
Fix:
Create Draft shortcut was not allowing selection of the new draft as a return value. The draft created is now available as a variable for use in subsequent actions in the shortcut.
Fix: Better handling of dark mode switching on iOS 12.
Fix: Landscape editing on iPhone did not take notch into account properly.
Change: “Backup Now” option for drafts now prompts for destination, rather than automatically saving to iCloud Drive.
Fix: Several minor layout issues.
Thanks for this. The special toolbar keys above the keyboard still continue to reappear even if hide keys is selected at some point after the app hasn’t used in awhile. This started with version 15.
I am aware of this issue and working on it. It’s a weird one to troubleshoot because it does not happen in debugging builds, only in release builds.
Sometimes you have to cut your losses. I have to support watchOS 6 and the latest SDKs, and the latest SDK, though they technically still support watchOS 4, shipped with so many bugs trying to run on watchOS 4 that the app was not reliable. If you love the Apple Watch, consider upgrading. The $199 Series 3 is SOOOOO much better than the Series 1. It’s a whole different world (and, yes, I understand that is not an option for everyone).
There’s times the app has to move forward to remain relevant and compatible for the largest number of customers. Building on Apple OSes is a bit like building on quicksand at times, things move so fast.
