Drafts 11 (macOS) is now available in the Mac App Store, details below.
New Version Numbering: Moving forward, each feature release of Drafts will get a major version number. Minor version numbers will still be used for bug fix and minor releases. If you look back, it’s the same thing we’ve been doing, but we’re dropping the “5”.
- Fix: “Open main window on launch” preference was not working properly.
- Fix: Clicking on dock icon should open main window if no other windows are visible.
- Fix: Prevent task marks from being marked as grammar errors when grammar checking is enabled.
- Fix: Hopefully a fix for case where duplicate drafts could get created from Share extension or other URL calls.
Change: If HTML passed to HTML Prevew has a
titleelement, use that title as the window title. - Fix: Several VoiceOver labels in preferences.
- Fix: New blank line at end of draft did not have the right line height/style until something was typed on the line.
- Fix: Merge operation did not properly pickup selected rows if you shift-selected a range for rows in list.
