I created an action to try and mimic the double bracket searching found in apps like nvALT and Bear. The search order is as follows:
- If a selection is made, search for that
- If no selection is made but one double bracket exists, search for that
- If multiple double brackets exist, prompt for which one to search
- Else, prompt for a search term
LINK: Double Bracket Search
Disclaimer: I started learning JavaScript last year when Drafts 5 came out so I could create actions. I’m sure the code is uglier than it could be BUT it should run just fine.
