I have a very old Mac and it has reached its limit with the Operating System, only going as far as Sierra. That makes it difficult to access Drafts and wonder if anyone has advice for me?
What kind of advice? There’s no workaround to use Drafts. Drafts never existed for Sierra, so there’s not an old version around anywhere that would run.
The current shipping version requires 10.13 (High Sierra), but the coming release will require 10.15 (Catalina).
You can export things from Drafts to text files on your other devices to iCloud Drive or other location that would be available to this Mac, but that’s about the limit.
You could try to install a newer version of OS X on your old Mac using OpenCore Legacy Patcher (OpenCore Legacy Patcher) and then install Drafts.
Thanks for the prompt answer. Appreciate it.
Sounds interesting. I’ll give it a try.
I would like to download draft to my Mac. Running iOS 10.14. How do I do that? In the App Store I can only see the current version.
Drafts is only available for macOS 10.15 or greater at this time.
