I like the idea of Scribble but I’m finding it impossible to get along with in Drafts. Should I persist with it? Or are other people also finding it a pain?
(Writing this question was problematic - so maybe it’s a general problem of mine.)
Scribble is great for search boxes IF you only enter plain text.
@nahumck wrote on MacStories that he is using it in Drafts for journals.
I loved the idea but have not dived deeper into it.
I think the scribble engine of Apple is not jet at full customer satisfaction level.
I like your Germlish typo “not jet”. I guess you meant “nicht jetzt”.
But I tease.
Thanks for your reply. And I’m glad @nahumck at least has made the leap.
There have been two identifiable issues so far for me:
I’m obviously on the steep part of the learning curve with Scribble. I’ll keep trying and learning - as Scribble might be viable and useful.
I’ve tried it a few times, mostly to test compatibility, but honestly can’t think of a case where it would be more efficient that typing in Drafts.
I get it’s usefulness in mixed drawing/note-taking environments, or could see it being useful popping out a Drafts slide-over for a quick thought while using the pencil for something else, but can’t personally see me using it in Drafts beyond that.
Right. I just thought I’d try it.
Given I’ve enabled Back Tap (2 taps) to create a new draft - on my phone - I have better ways to jot stuff down.
I played around with it during the beta period but quickly found it’s not really worth it. Might be great for quick idea capturing but longer note taking (like in a meeting or something) isn’t really usable. Sticking with Good Notes for now. It’d be cool if Drafts had a handwriting interface to it, but not sure if that fits with the how Drafts operates.
Agreed — I find it far more satisfying and efficient to write in goodnotes then dragging and dropping into drafts - that conversion is magical.
What do you drag into drafts? The handwritten note?!
Yes - it converts automatically to text. Much easier process than fiddling with scribble imho. https://www.macstories.net/reviews/goodnotes-adds-drag-and-drop-flexibility/
They is awesome! Thank you. Will definitely be trying that out today.
So that’s a conversion on the way out of GoodNotes rather than on the way into Drafts, right?
(And, yes, I have GoodNotes so this will work for me.)
Stray thought: It would be interesting to drag a Taskpaper list out of GoodNotes into OmniFocus.
I’ve never been able to get the drag and drop work directly to omnifocus - I usually need to go to Drafts first, since omnifocus views the dragged handwriting as a .png file. (Things 3 works, btw, but not as taskspaper, so you end up with a single task with several lines). But if you do get this to work, let me know!
Sounds like a drag out of GoodNotes contains multiple renderings - and OmniFocus picks the image rather than the text. But I will experiment.
This surely could be modified… https://www.peerreviewed.io/blog/sending-hand-written-tasks-from-goodnotes-to-todoist-using-shortcuts
EDIT: And it does - I have modified that shortcut. Not as quick as a drag and drop, but with this you can “convert” then run the shortcut and it adds them all to Omnifocus. Neat. I anyone knows how to include a step in shortcuts to convert text to task spaper, then this would be really useful!
Are you willing to share your modificatation
Let me know if this works https://www.icloud.com/shortcuts/36d502814ef747d5b5385b9ca1a516ce
Replaced Omnifocus with Drafts.
Still needs some thinking or tinkering
I still think drag and drop (or just copy/paste) is faster with drafts - this was an effort to get around the restrictions within Omnifocus.
