Hi,
Dictation language is always english no matter what’s selected in setting. Only after opening dictation setting language is set correctly. Have to do that every time.
Regards
Mick
Hi,
Regards
Mick
I did report that too but unfortunately mixed with other topics.
Until it is fixed a workaround could be to use a Dictate action. anyVariableForEditorContent = editor.dictate(yourLanguage); does recognise “yourLanguage” (formatted like “de-DE” for German, for example).
Or the microphone button on the iOS/iPadOS keyboard instead of Dictate in Drafts’ "+" drop down menu.
I did fix this for the last bug fix update, but it appears the fix did not get rolled into the final build. Apologies. It will be fixed in the next release.
Thank you very much. Good to hear.
Amazing (as ever). Thank you
