Hi all,
I am wondering if anyone has a fix for something that would speed up things for me. I often use Drafts as a quick inbox, but like to eventually file in specific Devonthink locations. While I have a variety of separate actions for particular destinations (which means my global inbox doesn’t get cluttered), I’d love to package these as a menu. In other words, once I have a note, an action that would give me quick set of choices of Devonthink destinations. Has anyone set up anything like this?
Thanks
I had built a js prompt in Drafts for something like this a while back but it was very difficult to maintain over time and I eventually resorted to using just the global inbox again. If I ever try do it again I might create an external dictionary of group names and uuid’s in either a Drafts file or maybe datajar and then use a prompt in Drafts to select from list. Maybe someone has a better idea
I went down a similar path, but found relying on dictionaries too restrictive, and keeping them up-to-date a pain. I’ve got fairly flat organization in DEVONthink - a few databases with key groups, and usually single tags for more classification. So 6 or 8 locations are my favorites, and tags specify the rest. Hard-coding all the most common tag options was not worth the effort.
Now I have Hazel watch an iCloud folder (my desktop, actually) for files that have a name that matches the pattern
d#tag filename
where d is a single letter that denotes a database or group. Hazel parses the filename into variables that I pass to a filing script. That script (JavaScript) has a switch statement to connects the single-letter location code to explicit database and group names, then lets Hazel move the file to DEVONthink via an AppleScript. Subsequent scriptlets put the DEVONthink item link of the import-rated file in markdown format into a Drafts note (where I can grab it in iOS or on the Mac) and another script sends me a text message confirming the details of the import. So I’m maintaining essentially just v small dictionary in the JavaScript script that handles locations, but after that tags are entirely free form. I like that this works as I save docs to my desktop from Mac or iOS, and I get a link i can readily work with if foe]r instance I want to incorporate into other working project docs.
Thanks all. Some good ideas here. I’m experimenting with using prompts for several usual places, but also the MD to DTTG action posted by @wonk71, which Sends markdown to DEVONThink To Go with prompts for Tags & Location. I’m trying to use a system of text expansion for a simple other locations (so “dt_st goes to my students folder, “dt_mee” to this years meeting folders, etc). I may find myself back dumping things in the inbox though in a few weeks
