Deleting a note and then using the up or down arrow in the message list column causes the first or last note to be selected depending on whether you clicked the up or down arrow. This behavior is very annoying if you are trying to delete many notes quickly in an effort to clean up the note list.
I’m forced to arrow up or down many times to get to the note directly below or above the one I just deleted. This makes the cleanup process nearly impossible because you have to try to determine where you are in the list of notes after every note is deleted. The process becomes impossible when you have over 1000 notes.
Can this issue be addressed?
