Every time I went into my draft, the cursor would by default be blinking at the bottom of my document in the draft.
But my Intention is to place the cursor at the start of the document.
Can anyone help me, thank you!
Here you go:
I had the same issue and this worked.
In general, Drafts tries to restore the last selected cursor position when opening a draft. If you want more control, try disabling the “edit on select” option in the Aa editor settings.
I tried and it works! Thanks
