Would Drafts be able to list and filter other drafts after typing [[ then characters to find drafts? Maybe only list drafts containing the first occurrence of one #?
Have you tried Greg’s action for inserting a draft link?
O_O
You… are awesome. Has anyone told you that?
(And Greg too.)
Hey, this is exactly what I want!
But I have a question… how do I invoke the action?
That is, when I’m in Drafts and want to insert a link, how do I get it to list other available drafts?
Thanks much!
You would invoke it in any of the ways you invoke any action in Drafts:
- Tap on it in the action list.
- Tap on it in the action bar below the editor.
- Use a keyboard shortcut you assign to the action.
If it is something you plan to you often, it’s likely you would want to make it easily accessible via keyboard shortcut (on iPad/Mac) or in the action bar group you use most often below the editor so it’s easy to find and tap.
This is exactly the information that I need! Thanks much.
I have a follow up question:
Can you tell me how to assign a shortcut to the action that I use?
That would be great for me. I’ve been searching the support documentation and can’t seem to find an answer to this question.
Sorry: I should have mentioned that I’m asking about assigning a shortcut to an action on Drafts on the Mac
Keyboard shortcuts are assigned on the action editing screen. Right-click on an action in the list, and select “Edit”.
