Cross linking a project between todoist and craft
this action is only useful for Todoist and Craft users. It could maybe be adapted for other Task managers or note apps (totally possible with Drafts itself) but I haven’t looked into this deeper.
I developed an action which is really useful when you often create project documents in Craft and would like to link them to a corresponding project in todoist
It prompts you for a title of the project and then creates the new project in todoist and a new document in Craft (based on a template) which are linked to each other.
The Drafts action can be downloaded here: create crosslinked project in Craft and Todoist | Drafts Directory
Hi FlohGro
I’m aware it’s been some time since you moved away from Craft, but I’m hoping you can still help :wink:
(Personally, I’m constantly switching between apps but Craft 3.0 had me curious again).
Anyway, I’m having an issue with “crosslink Todoist task & Craft document” – crosslink Todoist task & Craft document | Drafts Directory
When I execute the action I don’t see a link to Todoist appended to the Craft note (but I do get the link TO Craft in Todoist).
I’m not savvy enough to try to troubleshoot – so I was hoping you could take a look (and I’d be happy to ‘buy you a coffee’ for your time).
Best regards,
Anders
I will take a look but will need some time - a lot going on right now :wink:
Certainly, no rush! But great if you can find the time – sometime :smiley:
Hello again
Just to say – somehow the problem seems to have resolved itself (for now :wink:).
I actually tried getting Claude to help with the script a bit, but never got a good result (I know so little about coding I couldn’t really check the script, so it was pretty much a goose chase…).
Anyway, thanks again – and let’s hope it keeps working :partying_face:
