I am new to Drafts but wanted to see if anyone had any ideas about this. I would like to be able to use a key-combination to open the Quick-Capture window of Drafts, even if the app is not running.
I found a similar Keyboard Maestro action which uses Applescript to do the same thing for the Quick-Entry panel of Omnifocus. You set the Keyboard Maestro key combination to the same key combination as is set for Quick-Entry in the OmniFocus app. So when you hit that key combination, it checks to see if OF is open; if so, that key combination opens Quick-Entry. If OF is not open, that Key combination launches OF and then the Quick-Entry window.
Script is below.
OopsieFocus
A script to launch OmniFocus and activate the Quick Entry Panel
By Shawn Blanc (http://shawnblanc.net)
May 20, 2011
With code used from the Toggle Twitter script by Red Sweater Software:
http://www.red-sweater.com/blog/1646/toggle-twitter
Works great with FastScripts or Keyboard Maestro:
http://www.red-sweater.com/fastscripts/
http://www.keyboardmaestro.com/main/
How it works:
Set this script to run using the same keyboard shortut that you use to launch the Quick
Entry Panel in OmniFocus. If you ever try to activate the Quick Entry Panel but
OmniFocus happens to not be running, then this script will launch OmniFocus and bring
up the Quick Entry Panel for you.
set GTDAppName to "OmniFocus"
global GTDAppName
set GTDAppToUse to FindRunningGTDApp()
if (GTDAppToUse is null) then
set GTDAppToUse to "OmniFocus"
end if
-- Is OmniFocus running?
on AppIsRunning(GTDAppName)
tell application "System Events"
return (count of (application processes whose name is GTDAppName)) is not 0
end tell
end AppIsRunning
-- If OmniFocus is running, do nothing.
-- If OmniFocus is not running, launch it and bring up the Quick Entry Panel.
on FindRunningGTDApp()
if AppIsRunning(GTDAppName) then
null
else
tell application "OmniFocus"
activate
tell quick entry
open
make new inbox task
tell application "System Events" to keystroke tab
end tell
end tell
end if
return null
end FindRunningGTDApp
type or paste code here
Does anyone have any advice on how to adapt this to Drafts, and its Quick-Capture window?
